Mass flow rate at outlet
Old   October 18, 2004, 13:54
Default Mass flow rate at outlet
Leon
Is there a way to specify a mass-flow boundary condition (e.g. mass flow rate at outlet)? The inlet mass-flow rate is out of the question due to many considerations (compressibility effects with Mach number around 0.8 being one of them). Imagine a vacuum cleaner for which mass flow rate is known and you are required to estimate its efficiency in terms of what area it covers and how much of dust it sucks in.
Old   October 18, 2004, 17:07
Default Re: Mass flow rate at outlet
SAM
yes it is
/define/boundary-conditions/target-mass-flow-rate-settings>
there are two ways to define it . please refer to fluent users guide for description
regards
Old   October 19, 2004, 10:28
Leon
Thank you, SAM. It seems fairly easy indeed. Although a further step is required - an unsteady targeted mass flow rate at outlet. I have tried to hook up a udf procedure normally used for mass-flow_inlet and failed .
Old   October 19, 2004, 10:36
SAM
i have no idea for udf and unsteady flow fenomena
Old   October 19, 2004, 11:10
Default UDF with Targeted mass flow rate
Leon
1) A scalar was defined.
Then: 2) define -> boundary conds -> pressure ... [standard points] and:
Use profile for scalar value [no]? yes
Profile name [""] "udf"
data name [""] suck_in_rate
!!! And then it prompts: specify targeted mass-flow rate !!! What am I supposed to do?
Old   October 21, 2004, 20:25
Default Re: UDF with Targeted mass flow rate
Chetan Kadakia
If you know the mass flow at the outlet, just call it a massflow-inlet, but specify the direction to exit at the outlet.
Old   October 21, 2004, 20:31
Chetan Kadakia
And in that case, you can use a 0 pressure inlet too, since you are sucking in from atmospheric conditions. I use that all the time: pressure inlet at inlet, and mass flow inlet for the outlet.
Old   October 22, 2004, 07:36
Leon
Good suggestion. Thanks. Tried it in the first place though. Convergence was pretty awful. And it never worked with the coupled solver.
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 20:33
How Other Conditions Impact Mass Flow Rate Outlet andy P. Main CFD Forum 2 February 9, 2007 10:41
Inlet and outlet flow rate Neser CFX 1 March 2, 2004 16:02
Mass flow rate Neser CFX 4 February 14, 2004 00:27
