CAN THIS BE DONE?
Old   October 22, 2004, 05:36
Default CAN THIS BE DONE?
suresh
Can fluent be used to design the drying of a wet gas using a dehydrating agent like glycol. its like we introduce glycol into the gas stream and then remove it later becoz it doesnt mix.. but takes away the moisture content of the gas during its contact with the wet gas....CAN THIS BE MODELLED IN FLUENT...IF YES WAT MODEL IS TO BE USED...i wud appreciate any help... thank you
Old   October 22, 2004, 13:27
Default Re: CAN THIS BE DONE?
Ryan
Perhaps you could do this by creating a reaction where glycol + water --> hydrated_glycol. Set the species model to mixing rate/eddy diffusion and give the reaction a high pre-exponential and low activation energy. That way it will be mixing limited.
