Gambit and fluent problem
Old   November 2, 2004, 00:05
Default Gambit and fluent problem
Rezassp
I have two model . all details of two model is similar, dimensions , boundry condition type and value .but answers of models are different . models are drawing and meshing in gambit and analysis in fluent
Old   November 2, 2004, 01:09
Default Re: Gambit and fluent problem
Ammu
The meshing may be different. Check the number of cells in both. The mesh has to be made finer and finer till there is no more changes in the answers. Then we have a grid independent solution. We are supposed to reach there to get a correct result.
Old   November 2, 2004, 04:59
venugopal
if you using different type of fluent versions, there will be some change in answer. And also number of cells will differ the answer.
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 12:10
Fluent simulation problem & Gambit "database"error Chase Estrin FLUENT 4 February 21, 2013 04:15
problem gambit and fluent non premixed combustion LES ex-bmx FLUENT 0 April 23, 2010 18:24
Boundrycondition problem between Gambit and Fluent smalawi FLUENT 4 October 31, 2006 14:57
Gambit Meshing export to fluent minor problem John c. FLUENT 2 February 6, 2002 16:52
