cooling system
Old   October 29, 2004, 05:56
Default cooling system
spp
Hi; My physical model is a hollow vertical column with rectangular cross section. At the base there are two intake fans and at the top set of oil cooler and water cooler are fitted horizontally. The air is forced by fans onto the radiators and thus cooling them. Air flow rate is known. Can some one help me in:-
a.) Defining bc at air-radiator interface and at outlet.
b.) Explain whether radiator is to be modelled physically or to be treated as porous jump.
c.) If radiator modelled separately,two volumes to be merged or united.
Thanks in advance,
spp
Old   November 4, 2004, 02:00
spp
Thanks in advance,
spp
Cross Flow cooling system involving multiple fluids and a solid domain ajaymenon CFX 4 March 8, 2012 17:00
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
evaporative cooling system Athanasios FLUENT 0 February 10, 2006 09:14
Passive cooling system for batch reactor Darek Main CFD Forum 0 September 30, 2003 05:06
another question about engine cooling system marivani Main CFD Forum 0 February 2, 2000 11:55
