Home > Forums > FLUENT
periodicity problem
Old   November 9, 2004, 01:57
Default periodicity problem
prashant S.S
sir,
i'm working on combustor and i have taken 60 degree sector with swirler. during assigning a boundary conditions, i gave periodicity to swirler which is in interface with combustor inlet.when it is read in fluent, i am not able to create interface zone (swirler outlet with combustor inlet) and error comes with message"degenerated faces",is there any problem during assigning periodicity or model.please help!
Old   November 9, 2004, 04:08
Default Re: periodicity problem
annie
i think, the problem is perhaps not the periodicity BC. Perhaps is the grid of interface.
Old   November 10, 2004, 00:54
prashant S.S
hi!
you are right in saying ,i have a problem of grid interface.how to solve this problem? bye
Old   November 11, 2004, 11:39
annie
hi, have you solved your problem? If still not, perhaps the following can help you. Please expecially pay attention to two points: 1.please correctly set the rotation axis in fluid zone, if rotate 2. have you correctly set the periodic BC, if you use the periodic BC and the fluid rotate
if you have correctly set the BC, but it still don't work. Then check up if the two interface have the same geometry. Regards, Annie
Old   November 25, 2004, 10:43
Prashant S.S
hi!
i tried in fluent and error "degenerated faces" is displayed every time.so, i imported to CFX via TGrid and it is working very well. please suggest,why fluent is not considering this mesh. thanking you, prashant S.S
Thread Tools
Trackbacks are On
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
radial inflow turbine rotor periodicity problem Nanda FLUENT 1 July 17, 2006 14:52
radial inflow turbine rotor periodicity problem Nanda FLUENT 0 July 11, 2006 20:35
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
