HELP!what do the error message mean?
Old   November 10, 2004, 08:19
Default HELP!what do the error message mean?
Jiemila
Hello,Everyone,I began to use Fluent several month ago,and I am new comer.and my problem is as follows:
When I open a cas&dat calculated before, and then I want to display the result,fluent shows such error message as follows:
Error message from graphics function Update_Display: Unable to Set OpenGL Rendering Context
Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION). Error Object: ()
what does it mean? and how could I do?
Thanks a lot! Jiemila
Old   November 10, 2004, 17:41
Default Re: HELP!what do the error message mean?
Steve
what result are you trying to display? A line plot, plane contour, ??? You could try to generate a new surface to display results on instead of a surface previously defined. Let me know if this works, I think I ran into this problem before, although it might be a different error.
Steve
help:what kind model should I use. Bo FLUENT 0 July 25, 2008 09:56
