mushy model
Old   November 9, 2004, 03:47
Default mushy model
wanghong
Hi,all, who know how to specify the value of viscous resistance and inertial resistance in weld pool when you simulate mushy region fluid flow ,pls help me.i need good idea and reference articles. thank you in advance.
Old   November 10, 2004, 17:32
Default Re: mushy model
ymx
you can modify the viscosity or add a momentum resistence to the momentum equation. I prefer the second option. you can find details in following papers.
GL!!
Swaminathan, C.R., and Voller, V.R., 1993, ~{!0~}On the enthalpy method.~{!1~} Int. J. Num. Meth. Heat Fluid Flow, Vol. 3, pp. 233-244. Swaminathan, C.R., and Voller, V.R., 1992, ~{!0~}A general enthalpy method for modeling solidification process.~{!1~} Metallurgical Transactions B, Vol. 23B, pp. 651-664.
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
