November 21, 2004, 23:33 |
A tecplot problem
Hi All.
My model is a pipe flow, and the viscosity of fluid is variable in the flow field. The iteration had been processed in Fluent. Now I want to show the distribution of fluid viscosity, if which is larger than a constant value. At same time, I also want to show transparently the outline of the pipe wall. But I don't know how to show this two effects at one time. Pls someone give me any advices. |
November 21, 2004, 23:53 |
Re: A tecplot problem
you need to make two frames in tecplot to do this. set the features you want in each frame and make them transparent.
November 22, 2004, 04:43 |
cfdmonster,thank you.
I had gotten it. |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
Using Tecplot for contours display | david | FLUENT | 2 | August 23, 2005 22:37 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
