Crossflow Radiator Modeling
Old   November 15, 2004, 00:08
Default Crossflow Radiator Modeling
Ajit Kailasam
Hi
I need some help in modeling an automobile radiator. The heat exchanger is a crossflow 2 fluid stream HE. The problem is a 3D problem. I am unable to specify the flow of the second fluid (h20) through the pipes.
Fluent allows me to use the same fluid for both the flows.
Thanks
Ajit
Old   November 15, 2004, 17:51
Default Re: Crossflow Radiator Modeling
Aravind
did you add another fluid from the materials panel? if not do this
define-materials-database-click whatever fluid u want- copy that and then you are done. hope this helps. aravind
Slot jet in crossflow Sammy Main CFD Forum 2 September 16, 2009 00:55
Which is better project : 1. Analysis of two phase turbulent buoyant jet in crossflow jits_aps90 Main CFD Forum 1 July 29, 2009 06:31
Modelling a crossflow blower PAD FLUENT 0 August 30, 2006 01:38
Jet-in crossflow using Gambit Maged FLUENT 1 July 30, 2005 07:04
sonic Jet in crossflow (slot injection), cfl no amol palekar Main CFD Forum 1 November 14, 2004 20:46
