November 25, 2004, 14:00 |
Cd of cube
Hello.
I'm trying to test Cd of a cube but I get negative value! The one I get is around -0.03. It should be around 1.05 at Re=10^4 - 10^6. The following is the geometry of my cube, modeled with Gambit. Re= 3422.9395 Length= 1m Area= 1m^2 (Each edge of cube has 1m length.) V= 10m/s Density of flow=1.225 (air) I think I set proper reference values. A brick (flow area) is 10m*30m*10m and the cube is put 10m from the inlet, 20m from the outlet. Boundary condition of inlet is 'velosity-inlet (v= 10m/s' and for outlet I choose 'outflow'. If anyone could help me, please let me know. Thank you very much for your reading. Nagaru |
November 25, 2004, 14:33 |
Sorry
Sorry, Re=684587, Not3422.9395
Explosion inside a cube - blockMesh | shangzung | OpenFOAM | 3 | March 6, 2013 03:59 |
[ICEM] Icem Geometry creation strategy for hollow cube | tony00 | ANSYS Meshing & Geometry | 1 | March 16, 2011 11:05 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
drag calibration for cube | ga5aq | Phoenics | 7 | July 15, 2010 08:18 |
gmsh: Inner cube in outer cube | shangzung | OpenFOAM | 1 | October 7, 2009 06:14 |
