Flow Time
Old   November 18, 2004, 13:43
Default Flow Time
Tom berkvens
I'm looking for the text command that enables me to create a monitor that gives a parameter (for example pressure) with the corresponding flow time. I can create a monitor that gives me the parameter values, but FLUENT doesn't allow me to define time flow (as is possible in the GUI). The manual doesn't mention anything. Can anyone help?
Old   November 18, 2004, 16:55
Default Re: Flow Time
Luca
Try to explain better what you want to do... Anyway I know you can write a UDF (see the manual) containing a command RP_Get_Real(``flow-time'') to know the iteration-time. I hope it will be helpful for you. Luca
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
XY Plot vs Flow time HAR FLUENT 3 June 16, 2006 01:25
