PDF with Compressibilty Effects
Old   November 19, 2004, 13:17
Default PDF with Compressibilty Effects
Tang
I have a debate here with a collegue. We are conducting a first time CFD study here dealing with a gas turbine combustor connected to the high pressure turbine nozzle. The fast is that one of the guys here states that Fluent does not correctly predict compressibility results from the Partially Premixed PDF model within the high pressure nozzle due to the fact that the PDF was created using one pressure. I disagree with him since Fluent updates the values from the PDF table to account for the varying pressure difference within the combustor and HPT nozzle. I mean this is stated in the manual. My collegue assumes that there will be large pressure differences between a model using pure air and using the ideal-gas law turned on compared to the model that used the partially premixed PDF with compressibility effects, so he wants to turn off compressibilty effects. But the fact is that the HPT nozzle creates compressible flow and it would be computationally incorrect to model this case as a incompressible flow. I would like to know if anyone out in the Fluent forum can give their feedback about this or perhaps has done this experimentally or numerically.
Problems with non adiabatic PDF! Christoph_84 FLUENT 0 November 17, 2009 09:55
transported PDF for combustion (total energy PDF) mathieu ourliac Main CFD Forum 0 April 10, 2008 05:38
PDF Model in compressible flows with shock waves Hanxsi FLUENT 0 February 26, 2006 20:51
PDF - conserved scalar approach in KIVA vega Main CFD Forum 0 July 5, 2005 02:49
pdf method in kiva vega Main CFD Forum 0 May 16, 2005 03:45
