memory requirements - beowulf cluster
Old   November 18, 2004, 15:17
Default memory requirements - beowulf cluster
mary
I am trying to run a 3 million cell case on a cluster of dual processor, 933MHz PC's with 1 GB RAM on each computer. Does anyone have an estimate of how much RAM per million cells is required on the cluster PC's? I have been able to read the case in on 16 processes (giving me access to 8 GB of RAM) but it will not iterate. I have had success running a 2 million cell case on only 4 processes (2 GB of RAM).
Old   November 18, 2004, 15:44
Default Re: memory requirements - beowulf cluster
zxaar
i am currenly running a 3.something million cells case on double processor machine (windowsxp) .... it ocupies around 2.6 or 2.8 GB of RAM, the iterations are okey ..but it sometimes hangs while autosaving .... (FLuent support says its due to memory prob)
Old   November 19, 2004, 13:45
Default Communication Device?
mary
What communication device do you use?
I think I should be using Myrinet however when I try it I get the following error message ".../lnx86/gmpi/bin/mpirun No such file or directory"
The only communication device that works is Socket but I believe that it is the cause of significant decrease in performance (excessive paging)
Does anyone have suggestions?
Thanks
Old   November 20, 2004, 08:53
Default Re: Communication Device?
zxaar
to be frank i do not any inkling to it,
Beowulf Cluster configuration? inginer OpenFOAM 1 December 6, 2010 09:11
star 4.06 memory on linux cluster johnmck Siemens 7 April 22, 2009 13:02
Memory requirements for serial and parallel runs denner OpenFOAM Running, Solving & CFD 0 August 26, 2008 15:11
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
memory requirements Novak Elliott CFX 3 June 6, 2003 02:50
