December 1, 2004, 00:22 |
generating data file
hi there could someone point me a way to generate an output data file in the following format:
x-coordinate y-coordinate x-velocity y-velocity 1.0 2.0 4.5 6.7 1.2 2.0 4.6 6.8 p/s: export to ASCII format does not produce the above format. thanks in advance. yf |
December 1, 2004, 15:17 |
Re: generating data file
You should use a UDF. There are some macros yuo can use to get the informations you neeed. You can write a program using the C language and export what you need in a file. Hope it helps. Luca
December 1, 2004, 21:24 |
hi thanks!!
Display Modes | |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 17:46 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 12:40 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 12:47 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
