Home > Forums > FLUENT
changing porosity
Old   November 25, 2004, 07:55
Default changing porosity
mateus
Hi!
I have a problem with a flow trough porous zone... The thing is I need to define the potosity as a function of space and time - the porosity of the surface is not uniform and it also changes every timestep...
Is it possible to define that with UDFs?
Thanks in advance...
MATEUS
Old   November 27, 2004, 02:50
Default Re: changing porosity
wanghong
hi!
i am also modelling similar problem,but the porosity is needed calculated because it is a melting and solidification problem.defining your problem using UDF is needed further study FLUENT.
Old   November 29, 2004, 10:21
mateus
Hi!
Well it looks that I have a simmilar problem. The melted mineral wool is falling on the surface and solidifiing. The thickness of the layer changes the porosity of the surface...
Did you work with udfs? which ones
Old   November 29, 2004, 20:01
wanghong
yes.defining the viscosity and resistance coefficient AND temperature hoops using UDF.
Thread Tools
Trackbacks are On
energy changing associated with mass changing Martin duan FLUENT 0 August 6, 2011 12:42
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 09:02
Porosity field in Fluent wojciech FLUENT 1 September 20, 2010 11:19
UDF for porosity Giacomo FLUENT 3 July 23, 2007 09:23
porous media with variable porosity Kevin A. FLUENT 3 December 24, 2006 11:56
