Home > Forums > FLUENT
Cavitaation models
Old   November 26, 2004, 08:46
Default Cavitaation models
Alaa
Hello, I want to add or change the existing cavitation model inside Fluent. Is this possible or not? thanks in advance for replay? Alaa
Old   November 26, 2004, 09:53
Default Re: Cavitaation models
mateus
Hi!
It depends what you want to do. If you only want to use different bubble dynamics model you can do this by using UDFs. On the other hand I found it to be immosible to implement barotropic cavitation model (at least without the source code).
Hope this helps,
MATEUS
Old   November 29, 2004, 16:30
Default Re: Cavitation models
Alaa
Thank you Mateus, how I can use UDFs for bubble dynamics? I cannot figure where I can identify these new models. Alaa
Old   November 30, 2004, 06:32
mateus
Hi!
I think there is a example of cavitation udf in fluent udf tutorial.
mateus
Thread Tools
Trackbacks are On
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 22:31
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 10:35
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 04:21
informaiton about k-omega models krisreddi CFX 2 August 10, 2005 06:53
CFD models Xie Main CFD Forum 0 April 18, 2002 13:48
