CANNOT COMPILE
Old   November 29, 2004, 10:35
Default CANNOT COMPILE
Luca
Hi! I have a Windows Fluent version. When I try to compile a UDF I have the following error: cannot find nmake. I think nmake is used to compile my file.How can I solve the problem?Thanks in advance. Luca
Old   November 29, 2004, 12:01
Default Re: CANNOT COMPILE
HVN
What is your c compiler?
HV
Old   November 29, 2004, 12:54
Luca
I have Borland Turbo C++ and MS Visual C++. Please help...
Old   November 29, 2004, 13:12
HVN
For fluent, you need to use Microsoft Visual C++ 6.0 In a command prompt windows, could you type this 2 commands: cl and link/version. And then could you tell what are the messages?
Old   November 29, 2004, 13:20
Luca
nothing works (in Fluent text GUI or in windows prompt panel). the commands don't exist.
Old   November 29, 2004, 14:44
Luca
ok i typed at the prompt command in the VSC++ directory: vcvars32.bat
Now if I type cl the message is how to use cl. the link command works but i cannot make work link/version...maybe I mistake something... I wait fot your suggestions.Luca
Old   November 29, 2004, 21:31
Aravind
If you are using "Intrepret" for your UDF then make sure that you have the *.cas file, udfconfig.h and *.c file all in the same directory.When you read your case file you should read it from this directory which contains .h and .c files. If this doesnt work then copy the above three files and put it into C:\Fluent.inc folder, then it will work definitely. If your UDF (like DEFINE_CG_MOTION,DEFINE_GRID_MOTION) requires "compile" then you NEED to use VC++. Again make sure they are all in the same directory.
Hope this helps. Aravind
Old   November 30, 2004, 02:58
HVN
It means that your environment variables aren't correctly set-up. It explains why Fluent couldn't find the nmake command for compilation. Perhaps you need to reinstall the VSC++
Old   November 30, 2004, 13:41
Luca
Thanks Aravind, but I absolutely need to compile my function because I use the dynamic mesh.
Old   November 30, 2004, 13:44
Luca
At the moment I solved the problem by typing vcvars32.bat and then launching Fluent.Now everything kworks. Thanks HVN and Aravind for your precious suggestions. Luca
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
DUNS compile with VC++, VF or gcc/g77 in PC Ali Irvi Main CFD Forum 17 August 6, 2014 09:19
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 gwierink OpenFOAM Installation 0 April 5, 2011 04:38
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
