Draw velocity profiles in tecplot
Hi everyone:
My model is a pipe flow with one inlet and two outlets, which diameter is variable with the flow direction, and there is a symmertrical plane at Z=0 and XY-plane. The caculation had be finished in Fluent 6.1. Now I want to use Tecplot software to draw some velocity profiles (X-axis is the diametry, Y-axis is the velocity magnitude) within the symmertrical plane along the flow direction. I had tried many ways but no success. How can I do it? Please give me any suggestion, or if there is a tutorial ralated to the problem? |
Re: Draw velocity profiles in tecplot
You try to interpolate the field value in the fluid zone to the symmertrical surface firstly, then plot the velocity magitude.
