DPM concentration
Old   November 30, 2004, 22:50
Default DPM concentration
tian
I am running DPM in two-way coupling to obtain the concentratin. as the gas phase is steady state, i am not sure what the defination of concentration is in FLUENT using DPM. it is not given in user' manual. another problem is how to obtain the particle volume flux in a particular cross-section for steady state? thanks.
Old   December 1, 2004, 00:30
Default Re: DPM concentration
fpingqian
You can select Display/Coutour/DPM concentration(kg/m3). I think you can use UDF to obtain your second question. Hope can help you. Best regards fpingqian
Old   December 1, 2004, 01:55
Default thanks
tian
thank you for your help.
Discrete Phase Model and DPM Concentration Zach FLUENT 1 March 10, 2009 15:36
DPM concentration jack FLUENT 0 July 30, 2008 09:12
dpm concentration HK FLUENT 0 March 6, 2008 05:44
DPM concentration you FLUENT 0 May 28, 2001 10:24
DPM Concentration you FLUENT 0 May 23, 2001 03:59
