the error about boundary and turbulence
Old   December 2, 2004, 06:28
Default the error about boundary and turbulence
Gali
Hi all
My system is two phase mixing. One phase is gas and other is liquid. There are two input and one output. A input is velocity_inlet for gas and other is mass_flow_inlet for liquid.
When I do initializing , some messages appear.
The first message:
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2130 cells
The second message:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
What do they mean and how to straighten out ?
I change the boundary condition of the liquid phase and mass_flow_inlet changes to velocity_inlet. The second error message is gone. But I just know the mass flux of the liquid with experiment.
What can I do ?
Thanks
Old   December 3, 2004, 08:33
Default Re: the error about boundary and turbulence
Hongfw
About the first problem, you must reduce the value of the turbulence on the inlet boundary.
About the second problem, the direction of the inflow could not parallel with the inlet boundary. You try to chang the direction of the inflow, the problem would be settled.
Old   December 9, 2004, 20:22
chandra
may be u sould change the initial value before iterate, sometimes the value is unrealistic if u count from boundary.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
