Home > Forums > FLUENT
Adding an Axis to Contour plots
Old   December 2, 2004, 10:56
Default Adding an Axis to Contour plots
Lior
Hello everybody,
Does anyone know how can i add an axis (x-axis for example) to a contour plot (of temperature distribution, let's say)?
I would like the x-axis to appear beneath the temperature contour plot.
Thank you in advance,
Lior.
Old   December 3, 2004, 03:26
Default Re: Adding an Axis to Contour plots
Spymouse
If you know the start and end points of the axis, you can define a line as the axis. select surface/lineRake, input the start and end points. select create.
Old   December 3, 2004, 09:33
Lior
Thanks, but i am not sure that this is exatcly what i want to do... By adding a surface in line/rake function, all i get is a line... How can i add a line with a "ruler" beneath? I mean, with the numbers, for example from 0 to 100 millimeters??
Thanks again.
Old   December 6, 2004, 09:06
Mark
Hi Lior
You can add an axis to your contour plot as follows DISPLAY-->SCENE-->DRAW FRAME then select the lines on the box in the Bounding Frame window where you want the axes displayed (Section 31.7.10 of the Online User Manual)
Good Luck
Mark
Thread Tools
Trackbacks are On
CFX Contour Plots Troubleshooting derz CFX 7 November 21, 2010 11:08
vector plots and contour plots do not match swati_mohanty FLUENT 1 August 26, 2010 05:53
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
Contour plots Ale FLUENT 0 February 25, 2004 04:19
Local surface contour line plots Nandu FLUENT 0 November 10, 2003 00:26
