December 3, 2004, 14:46 |
Aeroelastic analisys of a plane
I'm working on an ambitious plan: a procedure for aeroelastic analisys of complete airplane (static aeroelasticity, flutter determination and fully coupled fluid-structure interaction). Now I have a huge problem: at university we have a home-made program for interpolating structure and CFD mesh. This means we use the dynamic mesh (DEFINE_GRID_MOTION) to prescribe the motions of every node. We don't know how to get the data(node positions) especially because we have to use the parallel solver. How to get the data in each compute node? By a UDF or by the export function (nastran or patran grid)? but the most important thing is: how can we prescribe the movement of the CFD grid for each compute node? Our program ( similar to a spring-analogy) can move every kind of grid. Please help.
Using a Plane id in Fluent UDF | cdf_user | Fluent UDF and Scheme Programming | 13 | October 17, 2023 00:06 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 07:16 |
