December 4, 2004, 10:46 |
Melting process
hi,
if im supplying heat flux on one sided of my 2D model,say to the side of a rectangle. Since heat flux is measured in w/m2, but my model is only 2D, so what is the default assumption in this case for the heat flux if i want to calculate the heat(joules) supplied? is it taken as per unit length? |
December 6, 2004, 08:27 |
Re: Melting process
In the default values menu you can set a depth value. All 2D analyses will use this depth value as the third dimension.
Hope this helps, Jason |
December 6, 2004, 08:46 |
Re: Melting process
hi jason,
where can i find this default value menu? couldnt find it in the content index... |
December 6, 2004, 17:13 |
Re: Melting process
Report -> Reference Values
Brings up the Reverence Values Panel (sorry about that, this is what I meant when I said default value menu). Hope this helps, Jason |
Simulate melting process of solid aluminium in liquid Titanium | anirudster | CFX | 8 | March 21, 2014 09:20 |
melting process for a pure substance | MASOUD | FLUENT | 3 | September 27, 2010 17:54 |
Which CFD software is suitable to simulate melting process? | sosososo1114 | Main CFD Forum | 1 | March 12, 2010 11:40 |
Modeling of Melting | James | FLOW-3D | 4 | March 8, 2009 00:27 |
study of a melting process | bryan | FLUENT | 0 | November 23, 2004 23:59 |
