How to model incompressible flow?
Old   November 24, 2004, 01:11
Default How to model incompressible flow?
luckyluke
How to model incompressible flow using Fluent code? I have select the "water" material for the fluid domain. Does anything else needed to be done?
Old   November 24, 2004, 03:25
Default Re: How to model incompressible flow?
ROOZBEH
Hi; If you choose "constant" option for density in material panel, this means thay you assume an incompressible flow. best regards ROOZBEH
Old   November 24, 2004, 04:29
nabeel mohsin
hi if you do not select energy equation i think it will also considered as nin compresible flow nabeel
Old   November 26, 2004, 01:28
Philipp Beierer
Hello, the only way to model compressible liquids in 6.1 is by defining your own routine in a udf (enabling the energy equation doesn't help you since that solves the ideal gas law). Release 6.2 should tackle this problem better. You may also see older postings concerning this topic via the search function.
May I ask what kind of flow problem you are trying to solve?
Old   December 3, 2004, 04:18
Aris
Ideal gases aren't compressible?
Old   December 7, 2004, 01:44
Philipp Beierer
Sorry, but I don't understand your question. My comment was in respect to the original posting of 'luckyluke'. If I remember right, he/she has been selecting water as the fluid in question...
Help: apply B.C. in my granular flow model ? Derek Jing FLUENT 1 January 8, 2020 21:38
Reynolds Stress Model incompressible sven OpenFOAM 3 August 29, 2012 13:13
Cavitation model with non-isothermal flow pitisrisuk CFX 0 July 14, 2009 14:30
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow harishg OpenFOAM Bugs 5 December 2, 2008 18:18
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
