UDF to change density in species transport
Old   December 8, 2004, 07:14
Default UDF to change density in species transport
Karthik
Hello all,
I am trying to fix upthe density values in a three dimensional cylindrical enclosure for which I give the density distribution at each cells. I am using species transport model. Interpreting does not display any result but when iterated Fluent displays error saying
"chip-exec: den_adjust: wrong return type: float udf function expected"
Could you please help to solve this problem. The udf i used is
#include "udf.h" DEFINE_ADJUST(den_adjust,d) {
Domain *d;
Thread *t;
cell_t c;
FILE *fp1;
real arr1=0.;
fp1=fopen("densitynew.dat","r");
begin_c_loop(c,t)
fscanf(fp1,"%g",&arr1);
C_R(c,t)=arr1;
end_c_loop(c,t)
printf("The density of cells are patched successfully");
fclose(fp1); }
Old   December 8, 2004, 07:45
Default Re: UDF to change density in species transport
Andrew Garrard
Well I am unfamiliar with reading in data from a file, but from your UDF I can see that you are trying to conduct a cell loop over a thread that has not been defined. I don't know if that is causing your error, but if it isn't, it would cause a different one.
When I am creating UDF's I usually make them very simple, see if they work and then increase the complexity. That way de bugging becomes very easy. Try getting C_R(c,t) to be a constant value first, and see if that works before trying to read from a file.
Old   December 8, 2004, 07:59
Chimwemwe Banda
Old   December 8, 2004, 08:31
Karthik
Thanks Andrew for your attempt. But i have tried with declaring the cell values with a constant density also. I face with the same error. I hope that this error is not due to the variable values but in some other thing. Whats wrong in "return type" that could be seen in the error message?
Old   December 8, 2004, 09:01
hongfw
If you amend your UDF like following, The problem may be solved.
Thread *t;
cell_t c;
FILE *fp1;
real arr1=0.;
thread_loop_c(t, d) { begin_c_loop(c,t)
C_R(c,t)=arr1;
end_c_loop(c,t)
} printf("The density of cells are patched successfully");
fclose(fp1); }
Old   December 8, 2004, 09:03
Andrew Garrard
It the first part of my message I mention this:
When you invoke the cell loop, you are applying a condition to every cell on a particular "cell thread". You delcare a thread pointer, in your case *t, but you do not tell the UDF what thread it is.
You will need to put in a line something like this
Thread *t = Lookup_Thread(ID, dom)
Where ID is the boundary ID, avaliable in the boundary condition panel and domain is your domain pointer, as passed in the argument of the DEFINE_ADJUST. There is more info at 6.5.7 in the UDF manual.
Old   December 8, 2004, 18:19
cg
Try using a
DEFINE_PROPERTY(lem_density,c,t) { real rho;
rho = ...
return rho; }
and hook this to density in the Materials panel
UDF species equations louiza FLUENT 4 March 10, 2010 01:20
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 03:06
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 09:53
Species Transport with Multiphase flow in FBR venkat FLUENT 1 July 23, 2008 23:53
Warning 097- AB Siemens 6 November 15, 2004 04:41
