December 9, 2004, 04:46 |
oscillating residuals
I'm modelling flow (steady state) over a ship at different wind angles. Some angles lead to a converged solution and others lead to the residuals (and surface velocity monitors) oscillating quite wildly as the solution proceeds after initial trend towards convergence. I've tried decreasing and increasing the under-relaxing factors, and have tried k-w and realizable k-e turbulence models. I'm using 2nd order or above discretisation. Anyone know why I'm still having trouble getting convergence? Thanks.
December 9, 2004, 15:28 |
Re: oscillating residuals
Chance is that the flow won't remain steady - shedding around the super-structure on the deck. You may want to model it using the unsteady solver option.
December 10, 2004, 04:01 |
hi check your momentum under relaxtion and meshing also nabeel
Reason for oscillating residuals | fayaazhussain | Main CFD Forum | 3 | August 21, 2014 11:31 |
oscillating pressure residuals buoyant plume | mabinty | OpenFOAM Running, Solving & CFD | 0 | August 31, 2009 06:31 |
Oscillating Residuals | Cairol | FLUENT | 4 | July 31, 2006 10:34 |
Oscillating Residuals | Cairol | FLUENT | 1 | July 28, 2006 02:47 |
Oscillating Residuals in Finer Mesh Case | Jake | FLUENT | 3 | June 16, 2005 10:34 |
