How to set the changeable boundary conditions.
Old   December 14, 2004, 03:39
Default How to set the changeable boundary conditions.
raintung
I use fluent to simulate the additional actuator, but i don't know how to set the changeable(or transient)boundary conditions, I hope someone can help me, thanks.
Old   December 14, 2004, 04:49
Default Re: How to set the changeable boundary conditions.
Andrew Garrard
The only way, I believe, you can set a boundary condition that changes with time (or for that matter any other variable) is to use a User Defined Function or UDF. If you use this forum much you will see that most of the questions regard UDF's. They are a very useful tool, and if you plan to use fluent alot they are well worth learning. However, they are quite tricky to begin learning. The best place to start is looking at the UDF manual supplied with fluent 6 or above.
If this is the only thing you will ever want to do in fluent, it is possibale to pay someone to write UDF's for you, but I don't know anyone who dose this. This saves you the time of learning how to write them yourself.
Old   December 14, 2004, 06:03
raintung
I see. I should learn more from you. Thank you.
Old   December 14, 2004, 06:48
Luca
If you have access to the Fluent user's site (www.fluentusers.com) there's the solution to your problem if I remember well. Luca
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Boundary conditions for simpleSRFFoam cnsidero OpenFOAM Running, Solving & CFD 5 May 17, 2017 11:26
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
