OVERSET grid
Has Fluent got the possibility of using overset meshes? Can't find anything on the user's guide. Gino
Re: OVERSET grid
There's no OVERSET in Fluent. We've run into the problem where we have some contracted CFD work that was done with an OVERSET grid, and now we can't use it on Fluent.
Sorry, and goodluck Jason |
Re: OVERSET grid
The alternative of overset grids is dynamic mesh in Fluent. I dont think overset grids will be employed into Fluent. Up to me, dynamic mesh is better cause as far as I know overset grids do not work with unstructured mesh at the moment and the interpolaton between two grids results in loss of accuracy. On the other hand, the drawback of dynamic mesh is the time consuming remeshing and not having the guaranteed mesh quality. Regards Emre |
Overset mesh is a new feature in Fluent R17.0 https://www.youtube.com/watch?v=NVRh99j1P1Y [Overset Mesh] in Fluent R17 Currently compatible for: Steady and transient (fixed mesh), 3D and 2D planar Pressure-based coupled solver Incompressible density method Single-phase or volume-of-fluid (VOF) multiphase Heat transfer k-epsilon and SST k-ω turbulence models BETA in ANSYS Fluent 17.0: Moving mesh Compressible flow VOF with surface tension Pressure-far-field boundary condition Workbench support Pressure-based segregated algorithms Best, hsz0566 |
