Home > Forums > FLUENT
limited turbulent viscosity
Old   December 21, 2004, 14:37
Default limited turbulent viscosity
ahourri
Hi all and happy hollidays: My problem is this : --Step 1: helium gas injection during 1 mn into a large cylinder filled with air at atmospheric pressure. The model is turbulent,compressible, time step 0.1 s. --Step 2: Stop helium injection and monitor helium equilibrium with air inside the cylinder during 250mn. During this step, along with the residuals , I monitor the average facelet velocity. For the fisrt few sconds , eveything was fine, afterwards, I have this message displayed : TURBULENT VISCOSITY LIMITED TO VISCOSITY RATIO OF 10E5. I changed the time step from 0.1s to 1s to 5s to 10s and I still have this message displayed. Am I doing something wrong, should the underrelaxation factor be pretty low or should I set an even bigger time step. Thanx for your help
Old   December 26, 2004, 12:29
Default Re: limited turbulent viscosity
emre
Search the archive, there is quite a lot messages posted on this subject..
Regards,
Emre
Thread Tools
Trackbacks are On
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
turbulent viscosity limited to viscosity ratio of? mechfloeng FLUENT 4 February 6, 2014 13:45
Turbulent viscosity limited to viscosity... Cyril FLUENT 16 October 4, 2007 06:12
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 21:34
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
