Home > Forums > FLUENT
non-positive volumn problem
Old   December 24, 2004, 02:14
Default non-positive volumn problem
wanghong
hi! "warning:non-positive volumes exist".anyone know why and how to deal with it? thanks in advance!
Old   December 24, 2004, 09:46
Default Re: non-positive volumn problem
Jason
That means there's a problem with your mesh. If you're 3D, then you've gotta go back to the actual mesh and find the problem. If you're using gambit, go to the mesh commands, volume mesh, and pick check mesh, then you can check each volume to find out which one has the bad elements, and then you can go from there to fix it. This is the same for a standard 2D mesh, except you would go to surface mesh instead of volume mesh when trying to find the bad elements. Also, the button all the way at the bottom and to the right on the screen brings up the mesh visualization tools. You can play around with the options to find the bad elements this way too (but it takes a while for meshes over 1,000,000... not sure how big your case is).
If you're using the 2D axisymmetric model, I believe you will get this error if you have any mesh below the x-axis. In fluent go to grid->translate and use this tool to make sure that your axis of symmetry lies on the x-axis and that the entire mesh is above the x-axis.
If this doesn't answer your q, then you might have to post some more details of your model (2D, 2D axisymmetric, 3D, your meshing program, etc...).
Hope this helps. Jason
Thread Tools
Trackbacks are On
engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 3 February 23, 2013 21:41
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
