Gambit problem
Old   December 24, 2004, 10:55
Default Gambit problem
Jason
I'm having problems with a mesh I'm building in Gambit.
Has anyone had problems when copying a volume with a mesh and the copied mesh has inverted elements? The first mesh is fine (max skewness ~ 0.7 and about 35,000 elements) but the copied one went nuts ( >200 inverted elements, and none of the meshes on the new faces line up properly). The same problem happens whether I copy the volume using a translation, a rotation, or a reflection of the volume.
Has anyone seen this problem before, and if so, how did you get around it?
I appreciate any help!
Thanks, Jason
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 07:58
Gambit installation problem Panos FLUENT 4 March 5, 2009 22:44
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
