Fluid flow will affect with different diffusivity? |
January 17, 2005, 01:41 |
Hello, I solved advection-convection equation with Navier-stokes equation for several different UDS diffusivity using FLUENT. I expected that the wall shear stress should be same even if the values of the UDS diffusivity are different, but the results are not. The advection-convection equation with fluid flow is one-way coupling, so the diffusivity does not affect the fluid flow. In fluent I set the numnber of user-defined scalar as 1 and the flux function is mass flow rate. Did I miss something? If you know the reason physically, please let me know. Thank you in advance.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
MR Fluid Flow through microchannels | Sinan | FLUENT | 0 | September 18, 2004 00:03 |
Fluid Structure Interaction | Apollo | FLUENT | 8 | July 7, 2004 17:54 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
