January 12, 2005, 12:08 |
Compiled UDF
I am trying to use compiled UDF with FLUENT 6.1. Somebody has some example of as to compile an UDF function?
January 13, 2005, 05:04 |
Re: Compiled UDF
The UDF manual that comes with version 6 or above has examples of both source code and procedure to complie it.
January 13, 2005, 12:57 |
Re: Compiled UDF
Thank Andrew Garrad
When I try the compiled my source file it shows the following message in the screen: 1 file(s) copied. The system cannot find the file specified. (system "move user_nt.udf libudf\ntx86\2ddp") 1 file(s) moved. 0 (system "copy \Humaita\Fluent.Inc\fluent6.1.22\src\makefile_nt.u df libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() Done Could you please send an example of how to compile an source file and an explanation for the type of problem that may be causing the above message? |
January 14, 2005, 05:11 |
Re: Compiled UDF
I am afraid that I have not seen that message befor, but I am not running a Windows Machine - I am using Linux. The info is at:
http://www.fluentusers.com/fluent61/...df/node130.htm Or if you haven't got a Fluent User account yet, try chapter 7.3 in the manual. |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Why udf can not be compiled in my pc? | Xinqiang | FLUENT | 0 | June 10, 2009 14:32 |
difference between udf compiled and udf interprete | chandra sekhar | FLUENT | 2 | April 11, 2006 00:04 |
how to quit compiled or interprited UDF | tian | FLUENT | 0 | April 8, 2003 23:53 |
