MSW gasification
Old   January 13, 2005, 19:08
Default MSW gasification
ernie
Anyone have tried modeling the gasification of biomass or Municipal SOlid Waste ? Some previewed journals using the Discrete Phase Model..or any suggestion which topic should i approach?
Old   January 14, 2005, 19:59
Default Re: 4-step method?am i right?
ernie
I would like to add some more:
i've gone through the biomass gasification which i don't think have much different with MSW gasification. In biomass gasification, the particles undergoes: 1. drying zone 2. volatilization zone 3. combustion zone
applying all these into Fluent, i'm thinking of using 3-step method(according to the number of zone)+ 1-step (on cold flow simulation) which are:
1-step: cold flow simulation 2-step: drying zone simulation 3-step: volatilization simualtion 4-step: combustion simulation
for each step, i have to get convergence value before i move to next step.
does all my assumptions are right?
I would like to hear any advice from you.
tq..
REgards, Ernie
Old   January 17, 2005, 13:06
Allan Walsh
We have run several models of biomass and MSW gasification/combustion in boilers with conventional grates.
What are your goals in doing the modeling? Trying to understand the process?
If the MSW will primarily be gasified in a bed, then you can probably preset gasification rates, species, enthalpy sources/sinks etc.
If you are interested in in-flight gasification and/or distribution effects of the MSW on gasification rates, then you might want to use the DPM model.
You can run an isothermal ("cold") flow simulation first if you want, but it won't give you any real information of the final flow conditions under gasification. To do that, you need to combine drying and volatiles release and whatever solid carbon reactions that are important to your process.
Remember, to get any meaniful results from your CFD modeling, you need to put some thought into what you are trying to achieve. You should check out the program "FLIC" from Sheffield.
Old   January 18, 2005, 20:49
ernie
Dear Sir,
Thank you with the advice.
For more info, we're runnning MSW incinerator. on the 1st chamber,it's the upraught fix bed gasifier. we'll use the simulation to optimize the 1st chamber in terms of its geometry.
Regards, Ernie
Old   January 20, 2005, 06:17
George
Hi Allan,
your work could be quite interesting to learn about - did you publish anything about your simulations or are your results classified?
Best regards
George
Old   January 20, 2005, 14:15
Allan Walsh
George,
Modeling work has all been done for industrial clients. You can find a few technical papers on boiler modeling at our company website - google "Jansen Combustion".
Regards, Allan
Old   January 24, 2005, 03:59
George
Thanks, Allan, I thought so.. It's natural and - I think that Ernie needs to consider some collaboration a with MSWI in order to get meaningful data.
Regards
George
Old   January 31, 2005, 16:32
Default Re: MSW gasification
ernie
I do have the chemical formula for the MSW and volatile percentage.do i have to obtain the chemical formula for volatile and char of mSW from experimental result? is there any other way since no published paper on mSW investigation in my region,
Old   April 12, 2012, 22:33
Default Flic
spz_zg is on a distinguished road
Remember, to get any meaniful results from your CFD modeling, you need to put some thought into what you are trying to achieve. You should check out the program "FLIC" from Sheffield.[/QUOTE]
Dear sir:
You have the "FLIC" software from Sheffield and the using method? I am very interesting in the incinerator bed modelling. Could you send this
to me?
All the best
spz_zg
spz_zg is offline   Reply With Quote
Old   April 19, 2012, 06:48
caner
crtv3366 is on a distinguished road
I am studing on plasma gasification of MSW wastes. HAve you got any fluent files for this subject. I want to look at all studies. PLease help me.
crtv3366 is offline   Reply With Quote
Old   April 30, 2013, 16:22
Bahram
bahramnourani is on a distinguished road
Please guide me to have FLIC software.
bahramnourani is offline   Reply With Quote
Old   September 27, 2014, 23:12
xingangzheng
ustbdynamic is on a distinguished road
dear,spz_zg:
could you send me a copy of FLIC code to me? thanks very much
Dear sir:
to me?
All the best
spz_zg[/QUOTE]
ustbdynamic is online now   Reply With Quote
Old   July 2, 2018, 03:48
Peter
PeterCFD is on a distinguished road
Originally Posted by ustbdynamic View Post
dear,spz_zg:
Dear sir:
to me?
All the best
spz_zg
[/QUOTE]
Can you share the FLIC software to me too? thank you very much.
pcjv4551@gmail.com
PeterCFD is offline   Reply With Quote
Old   December 7, 2018, 05:12
marco
marcogiub is on a distinguished road
exuse me guys, can I also have the FLIC software? I'm an engeneering student and I'm making a thesis on the model of an incinerator. My email is marcogiubila2@gmail.com
thank you very much
marcogiub is offline   Reply With Quote
Old   April 8, 2020, 16:56
Default FLIC Software?
  #15
Jhon_CFD's Avatar
Jhon_CFD is on a distinguished road
Dear all :
Anyone have "FLIC" software from Sheffield university ?
I am very interesting in solid waste fuel bed modelling.
Could you send it to me?
I really appreciate if someone does it, in case of big files, you could send them through wetransfer.com , my email is: NFLMALIK@GMAIL.COM
Thanks in advance
Jhon_CFD is offline   Reply With Quote
Nonpremixed Combustion Model for Coal Gasification C.Y.Ler FLUENT 2 April 29, 2014 08:51
Gasification reaction model Adi FLUENT 6 July 2, 2013 23:39
fixed bed gasification srr FLUENT 19 April 6, 2011 13:45
coal/petcoke gasification abhijay1987 FLUENT 0 December 24, 2010 04:23
Reg : Modelling of Gasification Using CFX S.SIVAKUMAR CFX 0 June 4, 2008 03:47
