3D Tip-Dihedral Wing Help
Old   October 20, 2015, 22:41
Unhappy 3D Tip-Dihedral Wing Help
Alex Petty
pettya is on a distinguished road
Hello I am an undergrad trying to analyze a tip-dihedral wing. I have a decent experience with static structural so making the mesh was not really a problem. Due to being tip-dihedral it can be ran as a 2D model
My total lift is coming out to be -.03lbf but according to hand calculations and prior senior design projects the wing should be at or around 55lbf.
I named my inlet velocity and outlet pressure. I am running steady state for time. My viscosity is is k-epsilon standard. I am just running the preset air in the fluent data base for a material. For the inlet velocity the magnitude is 50 ft/s with an x-component flow direction as 1. At the outlet pressure the gauge pressure is 0 lb/ft^2. My surrounding flow channel is set to interior. My reference values are computed from the inlet velocity. I did not mess with the default solution control. I am monitoring the residuals but plotting lift only in the Y direction (up). I initialization the solution from the inlet velocity. I am running my system until it converges based on residuals. I have tried mesh increasing the quality of my mesh but my numbers end up similar.
Any ideas?
pettya is offline   Reply With Quote
[ICEM] 3D wing tip realanony87 ANSYS Meshing & Geometry 3 November 6, 2019 13:34
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh yona ANSYS Meshing & Geometry 8 January 21, 2014 10:06
CFD of 3D Wing Tip Blowing NLao Main CFD Forum 1 March 1, 2012 01:44
[ICEM] Structured Mesh 3D Wing Tip Michiel ANSYS Meshing & Geometry 5 October 21, 2010 08:39
