Home > Forums > FLUENT
UDF help
Old   January 19, 2005, 16:25
Default UDF help
Hi all, I'm working on the unsteady compressible flow in a nozzle.I have attained a steady state solution and would like to set the conditions for unsteady solution.Can anybody help me with compilation and interpretation of UDF's for this case? Thanks, -kiran
Old   January 20, 2005, 06:45
Default Re: UDF help
Hi Kiran,
you should write a UDF using macros defined for particular vector or scalar variable and store it in src folder in home directory for your Fluent code. you can access this macro from Fluent window in File menu. you should not forget .c extension to signify C like code structure for your UDF.
Old   January 20, 2005, 10:40
Hi, Thanks swarup for your reply.I'll try that and get back if I have any more questions.Thanks again!! Regards, -Kiran
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
