Pressure Far Field BC
Old   January 20, 2005, 18:53
Default Pressure Far Field BC
Zhen
I use pressure far field BC's for my problem, but when I initialize, it says "bc type not handled Update_Fluid_Density". What does this error message mean? Thanks.
Old   January 20, 2005, 22:41
Default Re: Pressure Far Field BC
Zhen
Is pressure far field BC just for single phase? I use multiphase.
Old   January 21, 2005, 02:12
Riaan
Must use Ideal gas
Old   January 21, 2005, 10:36
Zhen
Yes, I used ideal gas. My model is multiphase/Mixture
Old   January 24, 2005, 07:53
Jason
Pressure Far Field was designed for aerospace. Its uses are VERY limited because it is a very sensitive BC. I don't think it can handle multiphase/mixture at all... when you say multiphase, I think of two phases being gas and liquid... since Fluent considers liquids to be incompressible, the Pressure Far Field shouldn't even initialize. I highly recommend switching to pressure inlet / outlet conditions. Pressure Far Field was originally designed for the aerospace industry to give a simple BC for analyzing wings and such. It has to be far enough from walls and any other inlets or outlets to avoid a gradient across it. Also, since it assumes constant Mach and Static Pressure, it has to be able to adjust the densities accordingly (which is why an incompressible fluid, whether gasseous or liquid, will not work). I don't believe it can handle gas mixtures either, but I could be wrong on that one.
Hope this helps, and goodluck, Jason
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
order of magnitude analysis atit koonsrisuk Main CFD Forum 3 July 27, 2000 11:59
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
