help! cyclone convergence question
Old   January 19, 2005, 21:04
Default help! cyclone convergence question
Lcw
I am doing simulation about cyclone separator by FLUENT, When I use RNGk-e turbulent model, convergence is easy to achieved, when I switched to RSM turbulent model, first residuals drop, velocity distribution looks like very good, then residuals rise abruptly and keep a horizontal level, velocity distribution deteriorates. All solving adopted PRESTO, QUICK scheme, and steady solver, and when using RSM, drop under-relaxtion facters a bit. How to keep RSM final convergence?
Thank you very much.
LCW
Old   January 26, 2005, 15:29
Default Re: help! cyclone convergence question
helper
Often times, with cyclones, the RSM captures the precessing vortex core which is an unsteady phenomena. When the RSM is used with the steady solver, the solutions would not converge, typically showing a limit-cycle like behavior. Try the same problem with the unsteady solver. Chance is that you'll see the RSM captures the precession of the vortex core.
Fluent: Tet Vs Poly mesh novice FLUENT 9 January 3, 2011 12:10
Convergence question with regards to discretization karananand Main CFD Forum 0 July 16, 2010 00:27
Question about convergence criteria? Thomas FLUENT 7 April 8, 2005 19:38
Discretisation / Convergence Question Johnny B FLUENT 1 November 15, 2003 14:27
Convergence Question Colin FLUENT 13 May 16, 2003 11:41
