import 3D I-DEAS mesh in Fluen
Old   January 27, 2005, 12:16
Default import 3D I-DEAS mesh in Fluen
Francesco Di Maio
Hi, I am trying to import in Fluent a 3D mesh (very simple) generated using gmsh and saved in I-DEAS format (*.unv). However, the Fluent fe2ram utility (fe432.exe) set to zero all the z-coordinates of the points in the Rampant file.
I have also tryed from DOS prompt the command
"fe432.exe -tIDEAS -d3 -oRAMPANT mesh.unv"
with the same result.
If I write manually the correct z-coordinates in the Rampant file, all is ok, so I am sure this is the unique (!!) error . Is this a bug of the utility fe2ram ?
Is there another method to import a mesh generated by gsmh in Fluent ?
Thanks for any help or suggestions.
Francesco
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Unable to import mesh on the CFX-Pre jarrai CFX 1 December 20, 2010 08:05
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
fluent add additional zones for the mesh file SSL FLUENT 2 January 26, 2008 12:55
CFX mesh import from ICEM (Windows) Andrew CFX 7 July 6, 2006 12:39
