February 1, 2005, 19:45 |
Error: open_udf_library
I am running Fluent 6.1.22 on a 64 bit workstation that's running fedora core with opteron processors. We are using the 32 bit fluent, as 64 bit won't be available for fedora untill version 6.2.
I have a udf that runs perfect on linux redhat. I compiled the udf on the new workstation (compiled fine), but when I try to "load" the udf, I get the message: Opening library "libudf"... Error: open_udf_library: No such file or directory I checked the directory structure and file content of the libudf directory. It is exactly the same as on the Redhat machine. Anyone know what this error is and / or how I can work around it? Interpreting the udf can't be done. Thanks Karl |
February 2, 2005, 08:51 |
Re: Error: open_udf_library
Usually this message means that FLUENT is not able to find the libudf.so compiled file.
This file is located in: 2D single precision solver -> libudf/lnx86/2d/libudf.so 2D double precision solver -> libudf/lnx86/2ddp/libudf.so 3D single precision solver -> libudf/lnx86/3d/libudf.so 3D double precision solver -> libudf/lnx86/3ddp/libudf.so Pay attention to put the source file of your UDF in the same directory where you saved the .cas file. Regards, ap |
