A hard one: how to get spanwise average in Fluent? |
November 5, 2009, 16:17 |
Ivan
Rep Power: 16 |
The computation domain is constructed by simply repeating structured 2D mesh in z-direction (spanwise), and I want to get the spanwise-averaged field variables. I tried but still could not find the way. I have thought of several methods as following:
1. Use UDF. The UDF will need to get the neighboring cell in z-direction. I don't know how. 2. Export data file from Fluent and do the average in Matlab. But the exported file is in PEBLOCK format, and there is a lot of connectivity information in the file, and I also don't quite understand the organization of data in that file. 3. Read the exported file or read Fluent case and data files directly into Tecplot and do the average. I checked and could not find the way to get spanwise average in Tecplot. 4. After reading files into Tecplot as in 3, export a file with better format (like IJK-ordered) from Tecplot, but I can only export files in FEPOINT or PEBLOCK format. Anybody any suggestion? Thanks! |
February 16, 2011, 08:54 |
zakk
Rep Power: 16 |
Hello Ivanbuz
I have been suffering about same problem. Do you have a solution so far? thank you |
February 17, 2011, 02:44 |
I've done it by using tecplot as an interface media, here's the instruction: - first by a journal file export number of planes data in span direction for tecplot. - write data exported in tecplot as new files. - export new files to matlab and compute the average. |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 6, 2018 23:37 |
Running fluent in UNIX | L3munoz | FLUENT | 10 | August 26, 2009 04:59 |
Fluent equation error?!? | TOM | FLUENT | 6 | July 15, 2002 03:24 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
How does FLUENT compute the average surface integral ? | Andre | FLUENT | 3 | December 21, 1999 10:40 |
