How to define boundary conditions for an oscillating heat pipe
Like Tree1Likes
  • 1 Post By yufeiai
Old   April 21, 2016, 16:19
Default How to define boundary conditions for an oscillating heat pipe
Yufei Ai
yufeiai is on a distinguished road
Hi guys,
I am simulating an oscillating heat pipe, which is a capillary tube arranged in a serpentine manner and forms a close loop. It doesn't have flow inlet and outlet. It is partially filled with water. Water evaporates and the vapor rises under the force of a heater at the bottom of the pipe. Vapor then condensed at the top of the heat pipe. Therefore it forms a two-phase flow in the pipe.
I'm wondering how I should deal with boundary conditions. There is motion with the fluid flow, but actually no inlet or outlet in reality. I'm not sure if I should define a velocity inlet or pressure outlet somewhere?
Also can I define a heat flux at the walls at bottom without UDF functions?
Thanks for any comment or suggestion!
yufeiai is offline   Reply With Quote
Old   April 21, 2016, 16:21
Yufei Ai
I did the simulation in ANSYS FLUENT.
dolati likes this.
Old   December 4, 2017, 08:56
Default can you share this? I get stuck in this case, too boring, I try my best to do this ,
judex is on a distinguished road
judex is offline   Reply With Quote
boundary condition, fluent, heat flux model, heat transfer
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
