February 6, 2005, 00:14 |
In-cylinder application
While doing In-cylinder application, I came across with some interesting findings. I am tring to simulate ideal compression process in 3D cylinder. After defining all In-cylinder parameters and zones details; I have solved the same case study with two different approach. In first one I gave the numebr of substeps in each timestep equal to 10 and in another one I gave 40. In both the cases, I found that the difference in maximum temperature is around 120 K ! which is amazing. Above this in both the cases the maximum temperature achieved after compression is not matching with the value that calculted using analytical formula. My question is how to select the number of substeps which will give the approproate results for in-cylinder application? Has any body come across such situation? Can any one share his/her thoughts on this. Regards, Yogesh |
February 6, 2005, 00:37 |
Re: In-cylinder application
number of time steps varies inversely to the time step size as far as i can recall doing an unsteady flow. The time step size is more significant a parameter than number of time steps. You would want to control the time step size and then calculate the number of time steps. There is a threshold value that you can calculate for a time step size using any of the CFD books available.
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
