Shock tube problem using fluent 5/6
Can anyome tell me how should I impose the Initial/Boundary condition if I am solving a 2D-shock tube problem using FLUENT. I have a high pressure (Driver side) and a low pressure (Driven side). How should I provide these BC's in the package after I have meshed the geometry. Thanks. |
Re: Shock tube problem using fluent 5/6
Ravi, You can setup your grid with two zones (one driver zone and one driven zone) and then patch different values for pressure etc. in each zone. Hope this helps, Regards, J
Hi Ravi,
far easier method to setting up a shock tube sim is by using a pressure inlet bc, specifying the conditions behind the shockwave. this removes the need to have two sep domains. as if you are only interestd in the driven section, the driver will jsut have a expansion wave travelling down it. nandu |
dear sir i have a CFD project aboute shock tube and i want some information about a fluent code and grid generation in this problem.
Hi Samaneh; Since I have been involved with gas turbine combustor simulation ,I have been working with stirred reactor and with some extent with shock tube.So please tell me what particularely are you intrested in the regard of shock tubes?Are you working on kinetic schemes?flame propagation or ignition and blow off? Regrads E.Alborzi
shock tube
hello,
could you please explain me how to give separate properties ( pressure, temperature and density) for the driver and the driven sections ? thank you :) |
hello, I just patch it like this, but it seems that the shock wave doesn't work well. Can you help me ? thank you.
hi menon,
i'm doing a project on shock tube simulation. can you please mail me your mesh and journal files of the shock tube for reference? it will be a very good help for me as i'm a beginner in cfd and i do appreciate your help. my email is charismaannjoseph@gmail.com thanks in advance! Quote:
Shock tube simulation in Fluent
Hi
Please go to this thread where I have explained some details about simulation of a shock tube in fluent: http://www.cfd-online.com/Forums/flu...tml#post497138 |
