NUMERICAL INSTABILITY FOR FLOW OV. SWIRLING VANES
Old   February 8, 2005, 14:44
Default NUMERICAL INSTABILITY FOR FLOW OV. SWIRLING VANES
D
Hi!
Has anyone observed the numerical instability over the swirling vanes. What we have is the flow over a set of vanes. We have pressure inlets and one pressure outlet. What we are observing is the mass flow rate through the pressure outlet is oscillating in a sinusoidal fashion.
Has anyone come across this kind of situation and has any comments/suggestions. We have tried with lowering the under relaxation factors. Even to a small number like 0.001, the mass flow rate is still sinusoidal.
Old   February 8, 2005, 16:36
Default Re: NUMERICAL INSTABILITY FOR FLOW OV. SWIRLING VA
helper
Some strongly swirling flows can have their vortex cores precessing - the vortex axis undulates in a snaky and unsteady fashion. Some advanced RANS models can often capture this phenomenon showing a limit cycle-like behavior of the residuals or oscillations in the solutions fields even in steady simulations. So, what you're witnessing may not be "numerical instability" but probably a physical one.
Old   February 9, 2005, 15:20
nobody
where is your pressure oulet located? is it at appropiate location?
Old   February 9, 2005, 15:35
D
pressure oulet is about an inch downstream from the end of the end of the vane.
TVD scheme Numerical Instability Tempa Main CFD Forum 0 June 29, 2011 01:54
Numerical Instability PattiMichelle Phoenics 2 December 26, 2005 19:49
NUMERICAL INSTABILITY OVER THE SWIRLING VANES Dan Main CFD Forum 2 February 9, 2005 08:12
Instability of convection Zeng Main CFD Forum 0 May 26, 2000 05:39
Problems of numerical instability because of high gradients Xiangyang Ye Main CFD Forum 4 September 28, 1998 03:48
