graphic window error
I have installed Fluent 6.0 on my notebook and I have a problem with the graphic window: when I try to plot anything on the screen (grid, residuals, surfaces...), it returns this message:
Error: Floating point error: divide by zero Error Object: () Can someone help me? Thank you. |
Re: graphic window error
I have the same prolem when i read the case from the Gambit. The error message is that:floating point error:invalid number.I search for the method to resolve it, but it is not fit for me. I am very anxious about it. If i know how to resolve it, i will publish the answer to here.
Try to run Fluent with command "fluent.exe -driver msw" - it helps in my case
Andrei |
Thanks, now Fluent works very well!!!
dear mattia:
what did you do for the graphic window error? Until now, i can not resolve the problem. Would you like patch the method in this forum? I want to see your reply. Many Thanks. |
