Cooper mesh
Old   February 7, 2005, 14:35
Default Cooper mesh
Samir
Hello Everybody,
I read a discussion related to structured and unstructured grids. And am working on a similar problem. details: Geometry: 3-D Y pipe bifurcation with reducing diameters all through. Mesh: I have created unstructured (tets), structured multiblock hex and am working on cooper scheme for the entire geometry since I was thinking about possible effects of alignment of the cells in the multiblock mesh. Problem: I cannot mesh a cooper near the region where the pipe disintegrates into two daugher pipes since the diameters are reducing (variable). I am yet to overcome this problem. It would be great if I can get some comments from you on the above. Thanks in advance. Best Regards Samir
Old   February 8, 2005, 14:26
Default Re: Cooper mesh
researcher
split and you will win.
Old   February 8, 2005, 16:36
Samir
I did, Thank you much. But, I was worried about the alignment of cells to the flow and if that affected the results. I'm working on that. Thank you and Have a good day. Regards, Samir.
Old   February 9, 2005, 10:33
Glufoureea
i'm afraid i can't offer any advice on this but i am in the process of modelling the same pipe arrangement. i had difficulty creating a smooth split, diameter reducing pipe. what method did you use to create the geometry?
thanks
Old   February 9, 2005, 14:11
Samir
The geometry does not belong to me!!
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
mesh volume: cooper scheme Usman FLUENT 1 January 19, 2008 04:40
