February 14, 2005, 04:35 |
different mass flow rates
hi anybody! I have problem with calculating the mass flow rate. I used the Turbo postprocessing panel for calculation mass flow rate (oultet) boundary. I was suprised when I calculated the mass flow rate using 'report-> surface integrals'. Calculated mass flow rate:
Density(average)*Velocity(radial,average)*Area =mass flow rate. Obtained mass flow rate using area- and mass-weighted average report types gave different m.f.rates than one calculated by turbo post. panel. Is my formulation of m.f.rate wrong, or just turbo post. panel has some bugs. Please help, I don't know which value is correct. |
February 14, 2005, 12:48 |
Re: different mass flow rates
Hi Micheal,
You should not average the values first. Rather, calculate the sum of Density*Velocity_normal*Area_normal. Fluent should have a function to calculate Mass Flow's directly, since the IP mass flows will differ slightly from this calculation. -Robin |
February 15, 2005, 03:24 |
Thanks a lot Robin. You have right. I have one question more: My problem is unsteady, so I would like to save mass flow rates through the inlet and outlet boundaries every time step. It is easy to save some quantities using
solve->monitors->surface-> and so on… But there is no possibility to monitor mass flow rate through the selected zone. Is there any easy possibility to do that without writing UDF (unfortunately T am not so familiar in UDFs)? best regards |
February 15, 2005, 20:47 |
I haven't the foggiest idea of how to do this in Fluent. I can tell you the expression for CFX-5, but that isn't going to help you much.
Regards, Robin |
February 21, 2005, 03:48 |
I think that you just need to use a Custom Field Function, not a UDF.
Regards George |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
Mass Flow Rate is not converging | destgir448 | CFX | 5 | December 11, 2010 05:55 |
Determine mass flow rate along flow path | Atit Koonsrisuk | CFX | 2 | October 5, 2003 04:47 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 17, 2003 19:23 |
