GAMBIT - Cooper Scheme
Old   February 16, 2005, 07:57
Default GAMBIT - Cooper Scheme
JB
I'm stucked w/ a meshing problem while using a cooper scheme. I get this error message : Assertion failed in BarrelCapStack. cc, line 57: NULL != next_cap while meshing volume.17.
Here is the description of my geometry: I have a 1 single volume that COULD be disretized in 3 volumes : the central one would be a regular hexahedron ; the two exterior ones would be two twisted hexahedra. total : 14 faces (6 source faces for the cooper scheme)
any idea why the cooper scheme does not work fine here?
Cheers, JB
Old   February 16, 2005, 21:01
Default Re: GAMBIT - Cooper Scheme
samir
A cooper scheme fails only if a geometry converges to a pipe. why exactly do u want a cooper; A mapped hex could replace a cooper. But it all depends on what your lookin for!
Old   February 17, 2005, 04:22
JB
I think I just Cannot avoid a cooper : I have no choice but meshing several source faces of my volume w/ a Tri-pave scheme. But what do you mean by "A cooper scheme fails only if a geometry converges to a pipe" ? I'm sorry, my english is not perfect at all. Anyway, If someone got a similar problem, I found a trick to avoid the pb: just split the initial complicated volume into several simple ones. That way I don't get error messages anymore.
Cheers,JB
Old   February 17, 2005, 08:31
Samir
Old   February 17, 2005, 08:32
Samir
Yes, I did have a similar problem and someone did say: Split and win. But , I had certain restrictions on splitting the volume. So, I said see what your lookin for and then make an optimum choice. Regards Samir.
Constant value by Cooper scheme Mohsin FLUENT 0 August 21, 2011 21:14
[GAMBIT] Boundary Layer without using Cooper scheme Lilly ANSYS Meshing & Geometry 6 March 17, 2011 15:14
Cooper Scheme Question (w/pics) Forrest ANSYS Meshing & Geometry 2 March 26, 2009 15:19
IMPRINT COMMAND IN COOPER MESHING SCHEME TINA FLUENT 3 October 7, 2006 05:03
Cooper Scheme Sandy Lawson FLUENT 0 December 14, 2004 06:43
