-   -   v2f model turn on?? (http://www.cfd-online.com/Forums/fluent/35760-v2f-model-turn.html)
Rain February 16, 2005 18:57
v2f model turn on??
How to turn on V2F TURBULENCE MODEL in fluent?
zxaar February 16, 2005 20:32
Re: v2f model turn on??
i think
(allow-v2f-model)
on TUI shall work
Rain February 16, 2005 22:49
Thanks. But the solution is not converging. The z velocity and f is not converging. How can I control them.
Rain
zxaar February 16, 2005 22:55
i never used this model ..so sorry i can't comment on this issue
yuvaraj saravanan February 17, 2005 02:20
Hi, Try running the solution initially using some ke model for flow field. define a custom field function(cff) v2 as (2/3)k where k is turbulent kinetic energy. Then turn to v2f model. Then patch a value for the velocity variance scale in all fluid zones using the cff that u created before.
Make sure velocity variance scale and elliptic relaxation function has the same discretization scheme as k and epsilon.
let me know whether it works Yuvaraj
Rain February 17, 2005 02:29
I am getting the solution converged but then i have TURBULENT VISCOSITY RATIO limited of 1.00+e5 in xxxxxx cells is coming. But then my case is high reynold number(15000) so should i just increase the limit or I should use the ADAPT/gradient/turbulent viscosity ratio to refine all the cells out of the limit(1+e5).
Jason February 17, 2005 07:58
I would refine... TVR of 1E05 is the same as quick drying cement.
Jason
